Jason, Just did my M axles. Drain rear end gear oil. I blocked rearend and put jack under frame rail do one side at a time do not want to tip it much..You will need to get the gaskets and seals. Pull out you PTO and shaft. Than you can losen the bull gear bolts I back my out and put them back about 3 treads. Take the axle bolts out. You should be able to pull axle out about an 1" to 1 1/4" enough room to clean all and get new gasket on with cut vertical at top. I buttered both sides with RTV. Bolt it all back up clean off RTV that sqeezed out. Do other side let it set 1 day before puting gear oil back. It is a job but it can be done. Oldiron29
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
