Re: Super M starves for fuel
Posted by El Toro on May 02, 2010 at 17:00:28 from (74.103.74.58):
In Reply to: Super M starves for fuel posted by Keno Farm on May 02, 2010 at 14:51:54:
third party image
Open that main jet adjustment screw to see if that fixes the problem. This will enrich your fuel mixture. Even garden tractors have that adjustment. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
