Super M starves for fuel
Posted by Keno Farm on May 02, 2010 at 14:51:54 from (71.53.92.254):
My Super M starts great with choke applied. Then when the choke is released the engine runs fine for 30 seconds or so then begins to act starved. Pulling the choke will revive the engine but it must be quickly released and then the whole process repeats itself. Adjustment of the fuel and air seem to have no effect. Any suggestions would be appreciated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
