Re: Super M starves for fuel
Posted by Armand Tatro on May 02, 2010 at 19:23:29 from (98.227.136.134):
In Reply to: Super M starves for fuel posted by Keno Farm on May 02, 2010 at 14:51:54:
Do you have that goofy fuel cap with the gauage in it? If so make sure the cork float is not coming apart as those pieces of cork can cause all kinds of problems! Also if you have a piece of hose in the fuel line it could be rotten on the inside and not letting fuel flow to the carb. Armand
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
