Re: Super M starves for fuel
Posted by Keno Farm on May 02, 2010 at 23:59:59 from (71.53.92.254):
In Reply to: Re: Super M starves for fuel posted by Rick(MN) on May 02, 2010 at 15:20:03:
Thanks for the suggestions. I have disassembled, cleaned and reassembled the carb, cleaned the filter and at the moment have no element in the filter. The supply line, screen etc are clean and non-restricted. Have decided to rebuild the carb as the best and only remaining option unless someone could offer a better suggestion. As I have told my son for years it only takes three things to make an old engine run - air, fuel and ignition. Seems like that is still a good rule.
Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
