Re: Super M starves for fuel
Posted by Rick(MN) on May 02, 2010 at 15:20:03 from (97.116.140.11):
In Reply to: Super M starves for fuel posted by Keno Farm on May 02, 2010 at 14:51:54:
Start by taking the fuel line off at the carb. Check to see that you have a good steady stream of fuel there. Reattach and pull the plug from the fuel bowl to check stream there, If both are good, then it is likely that you have an obstruction in either your idle or load circuits in the carb. One other thing, an intake leak will often show the same symptoms.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
