Re: Super M starves for fuel
Posted by Dougct on May 03, 2010 at 04:12:13 from (76.24.148.240):
In Reply to: Super M starves for fuel posted by Keno Farm on May 02, 2010 at 14:51:54:
I just went through this with my M.I even put in a new needle but because I let it sit and don't use it enough I found that when I pulled my bowl off the new needle was stuck shut,and yes I put treatment in my fuel.My solution was to shut the gas off so the float doesn't sit closed all the time and also i put in Marvel oil to lube it a little seems to work great now.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
