Update on F-20 that won't start/leaks around head bolts thre
Posted by Duanes on May 04, 2010 at 13:36:21 from (136.234.40.2):
We finally got the overhauled F-20 started. Apparently was a fuel line that was partially plugged. Even though gas was dripping farm carb it was still starved as we cleaned the line and put fuel in front two cylinders and it started.New found problem is the head is leaking up through the thread of a couple of the head bolts,we did get one to stop leaking. Any suggestions what may be going on here? Head was reworked at machine shop with the rest of the engine a couple of years ago and I assume they checked head for cracks (Reminder this tractor has been sitting for two years since overhaul). Front two cylinders are not firing now and I think that may be due to a leaking manifold gasket as there is good compression. Thoughts on this? This tractor was stuck when we bought and that is why we overhauled it. Pistons and sleeves were replaced with 4" ones.
Thanks!
