Re: Update on F-20 that won't start/leaks around head bol...
Posted by Janicholson on May 04, 2010 at 13:42:12 from (199.17.6.222):
In Reply to: Update on F-20 that won't start/leaks around head bolts thre posted by Duanes on May 04, 2010 at 13:36:21:
Drain the coolant
Clean the bolt with a wire brush
Put on Permatex #2
Put in torque to spec, run, torque to spec. Run Run Run Jim
