Re: H Hydrolics Info
Posted by ewalker on May 04, 2010 at 17:22:51 from (216.81.80.134):
In Reply to: Re: H Hydrolics Info posted by mkirsch on May 04, 2010 at 13:37:02:
I might have said that wrong, what I was wanting was to be able to leave the 3pt hooked up and run seperate hose for impliment and if I needed to raise 3pt I could and not actual move both at same time but move one then the other make sense? That way I could get a draw bar for the 3 pt and be able to adjust height if needed
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
