Re: Grandpa's 1941 H. Starter Troubleshoot
Posted by Lyle on May 28, 2000 at 19:57:09 from (199.224.92.199):
In Reply to: Grandpa's 1941 H. Starter Troubleshoot posted by The Red on May 27, 2000 at 09:48:14:
I had the same problem with my H and even though the cable from the starter switch looked good, I replaced it with a good copper one and it was like I had a new tractor. Good Luck
Post A Followup
: Re: Re: Grandpa's 1941 H. Starter Troubleshoot
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
