Re: IH 966 Broken Tie Rod end-Help!!
Posted by Gene-WI on May 07, 2010 at 04:00:39 from (74.117.241.1):
In Reply to: IH 966 Broken Tie Rod end-Help!! posted by Erik W on May 06, 2010 at 20:22:26:
Take your maul and hold against one side of the bolster, take a sledge hammer and give the bolster a good smack on the opposite side and the tie rod end will "squirt" out of there like you wouldn't belive.
