IH 966 Broken Tie Rod end-Help!!
Posted by Erik W on May 06, 2010 at 20:22:26 from (173.28.95.248):
Hi guys, long time follower of this site, and have learned alot. Now I need some help with a tractor broke down fin the field, and for the first time I can"t find any info.
Please pardon me if I don"t get nomenclature exactly right.
We snapped a tie rod end, the shaft that goes through the bolster, out in the field. We got the end off the tie rod easily enough, but are really struggling getting the shaft out of the bolster.
We"ve tried using a bottle jack from the bottom while supporting the top of the bolster to try to press it up, but nearly took the front end off ground and the shaft wouldn"t budge.
Is there some kind of special trick to get this out? Thanks a lot for any help you can provide, we"ve just got a few acres left to till before we can start planting beans, and we need this tractor to do it.
