If the hydraulic oil was leaking into the crankcase, and the previous owner were filling up the hydraulics every 2 hours, the crankcase would be full, and the engine would be smoking like crazy by the end of the day!
The hydraulic oil is leaking out on the ground. Right?
Changing the oil isn't going to help. If the oil was so bad that it was the cause of the problem, it wouldn't look like oil anymore. It would be a thick tar, or it would be clear water.
Changing the oil is a good idea if it hasn't been done in a while, but it sounds to me like there's either a restriction in the system somewhere, or the pump is shot.
There's a little cap on the left side of the hydraulic block that holds the filter screen. Pull it and see if it's blocked.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
