Re: Do I need a new hydraulic pump, on my international 140?
Posted by LotFotL on May 07, 2010 at 05:27:33 from (65.31.123.236):
In Reply to: Re: Do I need a new hydraulic pump, on my international 140? posted by mkirsch on May 07, 2010 at 05:18:49:
I've had the filter screen cleaned, and a gasket
around it replaced. That was were the leak was, but
it leaks no more. The leak would have been on the
ground.
So, how do I tell if there's a blockage or if the
pumps blown? Can I take off a line and see what
comes out and how?
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
