Re: IH 966 Broken Tie Rod end-Help!!
Posted by El Toro on May 07, 2010 at 05:41:46 from (74.103.74.58):
In Reply to: IH 966 Broken Tie Rod end-Help!! posted by Erik W on May 06, 2010 at 20:22:26:
If the sledge hammer doesn't work try some heat. Hal
