706 generator
Posted by jeff ruth on May 28, 2000 at 21:10:52 from (216.131.5.46):
I was told that you could replace the two six-volt batteries on the 706 with a 900 or 1000 cranking amp 12-volt battery with a little modification to the battery tray. Is this true? Will the generator charge a 12-volt battery?
Post A Followup
: Re: 706 generator
