Posted by rtb321 on May 11, 2010 at 06:36:54 from (69.207.67.77):
In Reply to: christmas tree valve posted by mkirsch on May 11, 2010 at 05:07:47:
mkirsch said: (quoted from post at 05:07:47 05/11/10) You're trying to use the belly pump lever to run one thing, and the christmas tree valve to run something else?
It doesn't work that way.
You need two christmas tree valves, or a second generic spool valve to do that.
no belly pump, live hyd. i'm trying to use the one way hyd on the 3 point hitch and the christmas tree valve for remotes. not nessesaraly at the same time but i do not want to mess with locking levers to use one or the other. it works now but with that lever slaming forward and sending the fluid through the pressure relief valve to feed the reservoir, im afraid the cam key won't be long for this world. am i going to need a aftermarket spool valve to replace that christmas tree valve? i was trying to keep it looking somewhat stock for the pulls, but it is my working tractor.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
