Just a guess on how you are hooked up. Is the pressure line from the pump feeding the remote control valve dirrect with a relief valve between pump and valve? Where does relief valve dump to? Is return outlet of remote contol valve going to the pressure inlet of the liftall unit? May be wrong on the guess, but guessing when the pressure builds up on the return outlet of remote control valve when using the liftall it pushes the spool up and then you're dead headed with no place for presure to go but the relief valve. If you put everything as IH intended for that system as Pete said, both the liftall and the remote control valve will work but not at the same time. Also the one not being used is locked back to use the other, what you don't want.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
