M charging???
Posted by oldiron29 on May 12, 2010 at 08:04:04 from (74.88.10.162):
I have had so many hand crank tractors with no electric now I am puzzled. (1944 M) I ran all new wiring as per Bob M #2 diagram. But new 3 post VR is not mounted on generator it is frame mounted. I Have new amp gauge that will discharge when you pull the switch so it is wired correct and working. I have done most of all the testing and troubling shooting as per John T charging system. All seems to test OK I have jumped wiring and grounding as he said. My question is how do you test the output of the genarator? Does anyone have diagrams for the genarator and brush adjustments? The gen is used off running tractor BUT! that does not meen it is working! I think this is my problem. Thanks for any help you may have Oldiron29
