Posted by glennster on May 12, 2010 at 09:11:15 from (75.57.131.175):
In Reply to: M charging??? posted by oldiron29 on May 12, 2010 at 08:04:04:
if you run the motor test from john t's chart, and the genny runs and then picks up speed, its prolly ok. grounding the field should put the genny to full output, generally 10-20 amps max. something to check that i ran in to was the terminal on the genny case was shorting out when i tightened the nut down. forget if was the f or a terminal, but the insulation was worn enough to short when tight.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
