Re: Re: Farmall M lost gears
Posted by Les Repair on May 29, 2000 at 17:43:54 from (206.28.174.170):
In Reply to: Re: Farmall M lost gears posted by Stan(VA). on May 29, 2000 at 16:40:23:
Another possibility could be the half moon key on the transmission input shaft. The way to check this is put the trans in gear(any gear) and also put the PTO in gear. If the PTO doesn't turn the problem is toward the front of the transmission, or maybe the rivits in the clutch hub are sheared off.
Post A Followup
: Re: Re: Re: Farmall M lost gears
