Re: Re: Re: Farmall M lost gears
Posted by Stan(VA). on May 29, 2000 at 18:53:31 from (207.172.106.55):
In Reply to: Re: Re: Farmall M lost gears posted by Les Repair on May 29, 2000 at 17:43:54:
Good point, Les.
If the PTO (and the belly pump hyd system) doesn't work either, then that would tend to point you closer to the front of the trany or the main clutch. If both of these do work, that would point you back toward the M&W clutch.
Stan(VA).
Post A Followup
: Re: Re: Re: Re: Farmall M lost gears
