The sediment bowl is directly above the starting lever. You may have to remove that panel to get at it..I think about 6 screws The hand primer is at the fuel pump , a little rod with a hook like end, turn the lever and start pumping. Pressure at the fuel filter? THe system is a closed system and the fuel is pumped through the filter so it is reasonable that there is pressure there...I would open the lines at the injectors and turn the engine until I had fuel pouring out, then reconnect and bleed as needed. This is likely something simple to be overcome but keep at it. My B250 is a little devil to get going after a filter change or if I run it out of fuel or a sediment bowl clog..once running it is a great tractor and very economical to use
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
