Re: International B-250 Diesel tractor
Posted by ErnieB on May 15, 2010 at 19:51:26 from (66.30.132.73):
In Reply to: Re: International B-250 Diesel tractor posted by Michael Soldan on May 13, 2010 at 06:59:12:
Michael, thanks again for the information. I spoke with the owner of the tractor today and he said that the fuel only dribbles out of the injectors when he cracks them open. It should be pouring out when he is cranking the engine so there may be some more bleeding to be done or another problem. Question - he should be opening the injectors at the valve cover or the top of the injector pump? Secondly could the injector pump be off of timing? Or do you think that there is just more work to be done with bleeding? Any pointers? Thank you.
