Re: 1939 FARMALL A STEERING PROBLEM
Posted by haas on May 13, 2010 at 16:54:39 from (75.235.49.114):
In Reply to: 1939 FARMALL A STEERING PROBLEM posted by Enar on May 13, 2010 at 14:13:45:
Have you replaced the bearing on the end of the steering wheel shaft? Any play in that bearing and you will have steering play. Also, the bearing must be tightly clamped (inner race) to the steering wheel shaft. And...the outer race has to be clamped in the steering box by the big hex plug on the front of the steering box. Sometimes it's necessary to put a machine washer against the race before installing the big plug to get it tightly clamped in the steering box. It it's not clamped in there, the result is steering play. Slso sometimes the woodruff key that is between the worm wheel and the vertical shaft will get worn and cause play. You said I belive, that you did not take the worm wheel gear out. Was it tight on the shaft and no play between it and the shaft???
