I did not replace that bearing. Perhaps I should. I did not know that the hex plug held the outer race. I'll check that. Where would you put a washer? There is not much room between the nut on the end of the steering shaft and the bearing. I thought that nut was holding the bearing. I think the worm wheel gear is a tight as it could be. If all else fails, I'll pull the front end again and replace the key.
Thanks for all your suggestions. (Don't go away. I made need you again!!!)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
