Re: Running Without Charging
Posted by IndianaRed on May 16, 2010 at 18:41:40 from (75.46.86.195):
In Reply to: Re: Running Without Charging posted by glennster on May 16, 2010 at 18:23:40:
No, I kept it negative ground, and got a new Pertronix 12V coil. I need a resistor on that?
And would that possibly cause the problem I described?
Thanks G
