Re: Running Without Charging
Posted by glennster on May 16, 2010 at 18:23:40 from (99.90.9.153):
In Reply to: Re: Running Without Charging posted by IndianaRed on May 16, 2010 at 11:58:03:
if you did a 12v conversion from a 6v system and are now using a negative ground, stop at napa and pick up a ballast resistor, they are about 6 dollars. get one for a mid 1970's b body chrysler automobile, the parts guy will know what it is and install it between the coil and the power wire feeding the coil. also, if you changed from a positive ground to a negative, you should reverse the small wires going to the coil.
