Re: Hydraulic valve for the H
Posted by DeltaRed on May 17, 2010 at 06:25:33 from (97.122.248.168):
In Reply to: Hydraulic valve for the H posted by williamf on May 17, 2010 at 02:04:32:
Sounds like you got it figured out.You could however,remove the rod and tie a piece of baling wire to hold the lever to open position.
