Posted by williamf on May 17, 2010 at 02:04:32 from (69.19.14.39):
I'm going to add some plumbing to my H so that I can use a disc with a two-way cylinder. I think that this is the kind of valve I'll need, but in a departure from tradition I thought I'd ask before buying.
I plan to put a T on the Liftall drain for the return, a second stub on the control lever rod to keep the pump flowing through the valve, and a post for the valve mounted on the axle housing where the fender would be bolted on, if I had a fender. What am I forgot?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
