And one more thought
Posted by ScottyHOMEy on May 17, 2010 at 22:05:12 from (64.222.223.103):
In Reply to: Re: farmall b posted by ScottyHOMEy on May 17, 2010 at 21:53:36:
Whatever you ultimately decide to do with the wire on the hot side of the ammeter, you may need to swap the wires on the terminals on the back side of the ammeter. 6v volt systems were typically positive ground, 12v are typicaly negative. If you don't swap the wires on the back of the ammeter, a perfectly good-charging ammeter will look to be discharging.
