Posted by MN Scott on May 19, 2010 at 20:56:11 from (12.157.197.253):
In Reply to: 560 running hot posted by Justintime on May 19, 2010 at 20:18:57:
Sounds like the thermostat is doing its job. The block should be hot enough that you can't hold your hand on it. If you are putting around the engine will not get hot enough to open the thermostat. You don't have to worry until it gets over 195 to 200 degrees.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
