Posted by Justintime on May 19, 2010 at 20:18:57 from (173.213.142.69):
I recently bought a 560 gas and just running it around the lot and tinkering with it, the block felt rather warm. I removed the thermostat and found it to be stuck. I replaced it but it still seems to heat up plenty. When I look in the radiator, I hardly see any movement. How much movement. This has me thinking waterpump but should I be checking somewhere else? I do not have bubbles or chunks floating in coolant. I have checked the coolant temp and it is not that hot 170-180 but for not being worked it just seems hot. I have more exp. with M's than the 6 cylinders. Thanks in advance.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
