Re: 560 running hot
Posted by El Toro on May 20, 2010 at 06:47:22 from (74.103.74.58):
In Reply to: 560 running hot posted by Justintime on May 19, 2010 at 20:18:57:
You may need to check your pump impellers for wear. Check the fins on the radiator to make sure there's no dirt or grass blocking the air flow. Hal
