There are some possibilities. If the coil is connected to a ballast resistor, the there may be a second connection on that terminal. It should go to the starter relay I terminal (four terminals two big, two small One small is a S the other is an I. If it is hooked any where else, or something is tee'd into that wire it might cause it. If the Voltage regulator input (ARM terminal) is connected to the ignition in any way it will cause it. (that wire has only two connections, one to the Arm terminal, and one to the Gen Big terminal. If the ignition controlled anti Dieseling Fuel shutoff solenoid on the carb is wired wrong, it might feed back into the ignition.
Trace the voltage with it running but OFF, and find its source. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
