Farmall 656 won't shut off
Posted by L Roth on May 21, 2010 at 15:41:03 from (71.50.60.24):
I am working on a Farmall 656 Gas tractor that stays running even after you turn the key off. It has to be backfeeding power from the charging system to the ignition. It is equipped with a generator and regulator. The regulator doesn"t have an ignition terminal so I guess you would call it self exciting. The only way you can shut it off is to slow the rpm"s down until the charging system stops working. The generator light will come on and the engine will shut off. My customer recently installed a new wiring harness in this tractor. I have checked it over with a wiring diagragm, and I can"t see anything that is hooked up wrong. Can anyone give me some advice? Thanks in advance.
