Re: Farmall 656 won't shut off
Posted by Allan In NE on May 22, 2010 at 04:24:09 from (148.66.88.254):
In Reply to: Farmall 656 won't shut off posted by L Roth on May 21, 2010 at 15:41:03:
Is the solenoid feed hooked to the correct terminal ("I") at the starter? If so, is the little return spring assembled properly inside the solenoid cap?
The primary ignition can only get fire from two sources, the resistor (via the ignition switch) and the solenoid. Make sure he hasn't tapped into either of those circuits and also at the coil "+" terminal.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
