Re: Farmall 656 won't shut off
Posted by El Toro on May 22, 2010 at 07:42:55 from (74.103.74.58):
In Reply to: Farmall 656 won't shut off posted by L Roth on May 21, 2010 at 15:41:03:
See if the wire feeding your ignition is connected to the correct terminal on the ignition switch. There should only be voltage present when the ignition switch is in the on position. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
