Re: Wide adjustable front end
Posted by Nebraska Kirk on May 23, 2010 at 17:49:46 from (207.91.4.141):
In Reply to: Wide adjustable front end posted by gene bender on May 23, 2010 at 17:42:16:
706 farmall said: (quoted from post at 18:42:16 05/23/10) I bought a wide front end off a 1256 and installed it on a 706, when installing it I noticed that the center pivot pin is sloppy between the axle shaft and the mount housing. Can the bushings or bearings be replaced? It looks like someone tried to shim front and back?
Is this a common thing?
Thanks
I don't think there are any bushings in that pivot hole. To fix it you would have to have the worn hole bored and a bushing installed, and buy a new pivot pin.
