Wide adjustable front end
Posted by 706 farmall on May 23, 2010 at 17:42:16 from (71.244.134.153):
I bought a wide front end off a 1256 and installed it on a 706, when installing it I noticed that the center pivot pin is sloppy between the axle shaft and the mount housing. Can the bushings or bearings be replaced? It looks like someone tried to shim front and back?
Is this a common thing?
Thanks
