Re: Wide adjustable front end
Posted by mazemeister on May 23, 2010 at 18:24:16 from (24.188.81.230):
In Reply to: Wide adjustable front end posted by 706 farmall on May 23, 2010 at 17:42:16:
not sure exactly what you mean- but there are 2 steel-backed brass bushings that press into the center hole on the axle tube, where it pivots on the pin. the pin has a clevis pin through the front that fixes it to the cast bolster. check the parts diagram. those bushings are i think 20 bucks or so from c-ih, then they have to be reamed to fit the pin (don't ask me why they don't just make them fit to begin with). if you're talking about fore-aft movement of the whole axle- that play is taken up by removing shims from the ball & socket at the rear of the wishbone. when that socket is as tight on the ball as reasonable, it will hold the axle forward.
