Re: Wide adjustable front end
Posted by MN Scott on May 23, 2010 at 19:27:42 from (12.157.197.253):
In Reply to: Wide adjustable front end posted by 706 farmall on May 23, 2010 at 17:42:16:
There are two bushings in the center axle tube. You can still buy the bushings from CNH. Just put a set in my 756 last winter. Your center pivot pin may be worn so measure it to. The forward backwards motion is controlled by the rear pivot ball. The ball or more likely its socket are worn to.
