fuel leak
Posted by stingray64 on May 24, 2010 at 05:46:12 from (74.195.253.199):
third party image
third party image
third party image
Asked before with great and varied response but now have pics. 1955 300-U. Gasoline engine. Fuel leaks from the bottom of the carb about 2 drops/sec. Didn"t before the rebuild. Used to start on second crank now takes a minute of steady cranking. Runs fine other than uses 2 gal/hr of gas. In the pics I have shoved a handy stick in the hole to slow the leak since it drains uncomfortably close to the exhaust. Am I missing a plug? Internal stuck part? Screw? Or just screwed? Thanks guys!
