Re: fuel leak
Posted by Handyman on May 24, 2010 at 06:18:42 from (216.201.66.220):
In Reply to: fuel leak posted by stingray64 on May 24, 2010 at 05:46:12:
there should be a bronze filter inside of that hole, it is there to drain water and gas out of the carb. what it is telling you is that your float or needle valve is not working properly. you need to disasemble your carb and find out why the needle valve isnt seating properly or adjust the float so it will close the valve.
