Re: 1930 Regular radiator not circulating
Posted by sgtbull on May 25, 2010 at 05:19:11 from (163.191.228.254):
In Reply to: 1930 Regular radiator not circulating posted by VER on May 25, 2010 at 05:06:15:
Did you put in antifreeze first, then fill it the rest of the way with water? If so, the antifreeze is much heavier, and until its mixed with the water, thermosiphoning is incapable of making the antifreeze rise to the top of the water. No circulation = HOT! I learned that the hard way on a John Deere G. Got it pretty doggone hot before I realized what had happened. Drained it into a bucket, mixing it in the process, put it back in, and everything was fine.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
