Re: Charging question
Posted by Janicholson on May 26, 2010 at 17:34:38 from (64.61.211.35):
In Reply to: Charging question posted by charlie M on May 26, 2010 at 05:29:53:
Take off one of the battery terminals. (either)
Use a small test light, or parking light with two leads. Place its leads between the post and the terminal you took off of it. if it lights, there is a current draw. If it is a one wire system, it might be the real issue. Con vert it to a three wire, or put a 50 amp toggle in the alternator wire to disconnect it when not running the tractor. Jim
