Re: Need ideals. Tractor running hot
Posted by LBSMJS on May 28, 2010 at 23:17:40 from (67.55.148.10):
In Reply to: Need ideals. Tractor running hot posted by Larry B 1486 on May 28, 2010 at 18:42:37:
Check your front pulley and see if it is loose from the rubber.If that is OK it could be the injection pump intravance is wore out or the front bushing has turned in the hsg.Had one that was worn enough that it melted the head arouund the valve area.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
