Posted by Larry B 1486 on May 28, 2010 at 18:42:37 from (67.142.161.33):
My 1486 has been running hotter than normal and today it almost touched the red. Did not come out the overflow so was going to look in the radiator and when I cracked the cap, it shot up about 10 ft and all the coolant shot up also. When cooled down it took about 5 gal to fill it back up. Have already changed the theromstat, new fan belts, washed radiator out thru the fins with a pressure washer, changed the fan blades from a 6 blade to a 8 blade (which made it run a little hotter yet. Don't understand that one) and radiator cap. Looking in the rad., it is flowing and no air bubbles or foaming or pressure untill it gets hot . Thought about replacing the water pump but no leaking and it is flowing good when you rev up the motor. What do I need to do????
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
