Purchase or borrow one of the digital heat guns. Check top tank temp vs bottom tank temp. Not enough coolant flow....large temp difference Not enough air flow.....small temp difference. Temp drop is usually 12-15 F for most designs.
Reason for large difference when not enough coolant flow, the coolant spends too much time in the radiator and the fan can suck more heat out. Causes? tubes partially plugged, water pump not efficient, hose collapsing internally, wrong head gasket, etc.
Not enough air flow, belts slipping, fan on backwards, radiator fins plugged, fan shroud missing, recirculating warm air back thru the radiator. (check that shields, air dams, and foam blockages are in place to prevent air recirculation)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
